Default Configuration for Generic Applet Types and Configuration of Non-Applet User Interface Constituents
This topic applies to the following:
Applets that use the default configuration for generic applet types. Such as List, Tree, and so on. In other words, applets that have not been mapped to any Manifest Key specific to an individual applet.
Other user interface elements. Such as navigation user interface elements other than applets, whose keys are defined within the implementation itself, in other words, not through user properties or through the mapping file.
File downloads that occur during the application startup.
For generic applet types, the UI Object applet is populated with records with well known values for the Name field. The following table lists these values.
| Key in the Legacy Manifest File | UI Object Type | UI Object Usage Type | Generic UI Object Name | Description |
AppletPM |
Applet |
Presentation Model |
DEFAULT FORM APPLET |
Key from the default Form Applet Presentation Model. |
AppletPR |
Applet |
Physical Renderer |
Key for the default Form Applet Physical Renderer. |
ListPM |
Applet |
DEFAULT LIST APPLET |
Key for the default List Applet Presentation Model. |
ListPR |
Applet |
Physical Renderer |
Key for the default List Applet Physical Renderer. |
TreePM |
Applet |
DEFAULT TREE APPLET |
Key for the default Tree Applet Presentation Model. |
TreePR |
Applet |
Physical Renderer |
Key for the default Tree Applet Physical Renderer. |
ScreenPM |
Navigation |
NAVIGATION CONTROL |
Key for the default Navigation Control Presentation Model. |
RestOfUIPM |
Application |
Common |
PLATFORM INDEPENDENT |
Key for Presentation Model implementation of parts of the user interface other than those with specific keys for their default implementation, such as Menu, Toolbar, and so on. |
RestOfUIPR |
Application |
Common |
PLATFORM DEPENDENT |
Key for Physical Renderer implementation of parts of user interface other than those with specific keys for their default implementation, such as Menu, Toolbar, and so on. |
NAVIGATION_TREE |
Navigation |
Physical Renderer |
NAVIGATION TREE |
Key for the default tree Navigation Control Physical Renderer. |
NAVIGATION_TAB |
Navigation |
Physical Renderer |
NAVIGATION TAB |
Key for the default tab Navigation Control Physical Renderer. |
