Starting Upgrade Tuner
Use this procedure to start Upgrade Tuner.
To start Upgrade Tuner
Enter the following command:
SIEBEL_ROOT\bin\upgtuner /c LOGPARSE_SUMMARY_LOCATIONLOGPARSE_SUMMARY_LOCATION is the location of the summary.xml file generated by the Logparse utility for the production upgrep. For example:
upgtuner /c SIEBEL_ROOT\log\upgrep_prod_77\summary.xmlThe Upgrade Tuner Process Information page appears.
Alternative: Start Upgrade Tuner without the
/coption. Click OK at the error pop-up. When Upgrade Tuner displays, click Browse and navigate to the summary.xml file.
