Authorization Requirements for Performing Upgrade Procedures on the z/OS Host
The user who performs upgrade procedures on the z/OS host requires the following authorities and access:
  • A thorough understanding of zSeries architecture, JCL, and TSO functions and navigation.
  • A TSO account with the authorization to allocate/create data sets on the z/OS host using the high-level qualifier specified in the FTP script.
  • Access to the DB2 staging and target system.
  • DB2 authorities to create DB2 objects and create DB2 VSAM data sets.
  • Grant and Bind authority.
  • DB2 Workload Manager refresh authority.
The default JOBCLASS is Q. Make sure you use the correct job class in the generated jobcards.
