Executing the Incremental Repository Merge Under UNIX
Use the following task to execute the incremental repository merge if you are running the Siebel Database Configuration Wizard on UNIX, or if Siebel Tools is installed on UNIX.
Incremental repository merge is started automatically under Windows, but under UNIX you must initiate the process manually. You begin executing the incremental merge when the Upgrade Wizard pauses and notifies you to execute the manual merge.
To execute incremental repository merge under UNIX
Copy the irm_sav_file.ssf from
SIEBEL_ROOT\bin
from the UNIX computer toTools_ install_directory\bin
on the Windows computer.Execute the following command to start the incremental repository merge:
siebdev /u UserName /p Password /d "ToolsDataSource" /c"SiebelToolsRoot\BIN\$Language\tools.cfg" /iPackmode /IRM UpgDeltaMerge
Click Yes to continue.
To pause now and resume later, click No. To resume, see Starting the Siebel Upgrade Wizard.
