Getting Status for a Running Migration Plan by Name
You can get status for a running migration plan by name for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get status for a migration plan by name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}
HTTP Method: GET
Content-Type: application/json
Authorization: Basic
Request Body: None
The following are the details for the response to a successful request:
HTTP Code: 200
Response Body:
{ "id":"88-1V5WPF", "planName":"IRRMigration", "description":"IRR Migration", "status":"Running", "startDate":"2018-07-17 04:33:54", "endDate":"", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5WPG", "name":"", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Not Applicable", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPH", "name":"", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Applicable", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPI", "name":"", "operation":"Export", "sequenceNumber":"3", "mode":"Asynchronous", "status":"Running", "startTime":"2018-07-17 04:33:55", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPJ", "name":"", "operation":"Import", "sequenceNumber":"4", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPK", "name":"", "sequenceNumber":"5", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPL", "name":"", "operation":"DBCheck", "sequenceNumber":"6", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" } ] }
