Difference Between Deleting Development and Integration Workspace
The difference between deleting a development Workspace and an Integration Workspaces are highlighted in the following table.
| Development Workspace | Integration Workspace |
Can be deleted by the creator of the Workspace or any user that has the Workspace Administrator responsibility. |
Can be deleted only by users that have the Workspace Administrator responsibility. This user must ensure that there is no one actively using the Workspace or any of its children because the deletion is permanent. Note: If the Workspace or any of its child Workspaces are configured for
migration, then you cannot perform migration once the source Workspace is
deleted.
Can be deleted only if the status on the Workspace Dashboard is not Delivered or Submitted for delivery. |
Can be deleted only if the status on the Workspace Dashboard is not Edit-In-Progress or Rebase-In-Progress. It is not possible to rollback the deletion to recover data. This is an administrative activity. |
Can be deleted only if there are no child Workspaces associated with it. |
Can be deleted even if there are child Workspaces associated with it. |
