Supported Objects and Features
The following features are available and supported in Web Tools:
Locking and unlocking projects in the local repository for non-Workspace objects.
Configuring symbolic strings.
Adding to archive.
Sorting on objects.
List of Values, Analytic Strings, and System Preferences.
Using Object Explorer and Object List Editor.
Using Siebel IDE for layout editing.
IO deploy/undeploy.
Using the Siebel Script Editor, the eScript Engine, and the Siebel Debugger.
Setting debug options.
Workflow Editor.
Task Editor.
Validate Tool.
Validating objects, Workspaces, tasks, and repositories.
The following objects are available and supported in Web Tools:
Applet
Application
Business Component
Assignment Attribute
Assignment Criteria
Bitmap Category
Business Object
Business Service
Class
Command
Content Object
DLL
Dock Object
EIM Interface Table
Find
HTML Hierarchy Bitmap
Icon Map
Import Object
Integration Object
Link
Menu
Message Category
Pick List
Project
Repository
Schema Maintenance Phase
Schema Maintenance Process
Schema Maintenance Step
Screen
Symbolic String
System Activity Object
Table
Task
Task Group
Toolbar
Type
View
Web Page
Web Template
Workflow Policy Column
Workflow Policy Object
Workflow Policy Program
Workflow Process
