Using Breakpoints
A breakpoint is a marker in a line of code that stops code from running at the line marker, thereby allowing you to examine the state of the program at that line.
To use breakpoints
Do one of the following in Siebel Server Script Debugger:
Place the cursor on the line of code where you want to set a breakpoint, and then click Toggle Breakpoint on the Server Script Debugger toolbar. For more information about the Server Script Debugger toolbar, see Accessing Siebel Server Script Debugger.
Place the cursor on the line of code where you want to set a breakpoint, and then select Toggle Breakpoint from the Debug menu.
Click the gutter area adjacent to the line of code where you want to set a breakpoint to turn on the breakpoint.
Position the cursor in the gutter area adjacent to the line of code where you want to set a breakpoint, right-click and then select Toggle Breakpoint from the popup menu that appears.
If a breakpoint already exists on the line of code, then the breakpoint is removed. If a breakpoint does not already exist on the line of code, then a breakpoint is added.
