Simple Query Operators
The following table describes the operators that you can use to create a simple query. A simple query is a type of query that locates records according to one condition. A check mark in a property that can contain a Boolean value represents TRUE. The Changed property is an example of a property that contains a Boolean value. For more information about query operators and Siebel data types, see Siebel Developer's Reference.
| Operator | Description |
Equal to (equals operator). |
Less than (opening angle bracket). |
Greater than (closing angle bracket). |
Not equal to (opening angle bracket and closing angle bracket). |
Less than or equal to (opening angle bracket and equals operator). |
Greater than or equal to (closing angle bracket and equals operator). |
A wildcard. An asterisk ( |
A wildcard. A question mark ( |
IS NOT NULL |
Queries for a property that is not empty. |
IS NULL |
Queries for an empty property. |
LIKE |
Queries for a value that begins with the string that you enter. |
NOT LIKE |
Queries for a value that does not start with the string that you enter. |
Queries for a string that includes a special character. For example, enter |
EXISTS() |
Queries for a value in a multi-value group. |
Forces the text string to use the case that follows the tilde ( |
