Using the Locale Management Utility
This topic describes how to use the Locale Management Utility. It includes the following information:
The Locale Management Utility (LMU) is a utility that you can use to manage how you configure Siebel CRM to localize text strings (such as field labels) and other locale properties (such as the height and width of controls). You can use it to export text strings to a file. After Siebel modifies or translates these strings in the file, you can use the Locale Management Utility to import them back into the repository. The Locale Management Utility also includes search and comparison tools.
