ODBC Close Connection Method
The ODBC Close Connection method is a Siebel VB method that disconnects from an ODBC data source connection that the ODBC Open method established. It returns a variant that includes one of the following values:
0. Successful disconnect.
-1. Connection is not valid.
If you call the ODBC Close Connection method with an argument that is not valid, then it replies with the undocumented return code of -2 (negative two), which indicates a data source connection that is not valid. The following items are examples of arguments that are not valid:
An SQLClose(0) argument
A variable argument that does not contain an initial value
Format
SQLClose(connection)
The following table describes the arguments that you can use with this method.
| Argument | Description |
connection |
A named argument that the ODBC Open method returns. It must be a long integer. For information about named arguments, see Comments and Call Subroutine Method. |
Example
The following example opens the data source named SblTest, gets the names in the ODBC data sources, and then closes the connection:
Sub Button_Click
' Declarations
Dim outputStr As String
Dim connection As Long
Dim prompt As Integer
Dim datasources(1 To 50) As Variant
Dim retcode As Variant
prompt = 5
' Open the data source "SblTest"
connection = SQLOpen("DSN = SblTest", outputStr, prompt: = 4)
action1 = 1 ' Get the names of the ODBC data sources
retcode = SQLGetSchema(connection: = connection,action: _
= 1,qualifier: = qualifier, ref: = datasources())
' Close the data source connection
retcode = SQLClose(connection)
End Sub
