Trim Spaces From String Method
The Trim Spaces From String method removes leading and trailing spaces from a string. It returns a copy of this string with the leading and trailing spaces removed. Note the following:
It accepts expressions of type string.
It accepts any type of string, including numeric values, and converts the input value to a string.
If the value that the string argument contains is NULL, then this method returns a Null variant. For more information, see Variants.
Format
Trim[$](string)
For information about the dollar sign, see Usage of the Dollar Sign.
The following table describes the arguments that you can use with this method.
| Argument | Description |
string |
A literal or expression from which this method removes leading and trailing spaces. |
Example
For an example, see Get Substring Method.
