About Making Literature Visible to Users
You can make literature visible to users in the following ways:
    The Products Screen. You can associate literature with a product, and the user can display it using the Products screen.
    The Competitors Screen. You can associate literature with a competitor, and the user can display it using the Competitors screen.
    The Decision Issues Screen. You can associate literature with a decision issue, and the user can display it using the Decision Issues screen.
    The Correspondence Screen. You can deselect the Internal field of a literature record and the user can select it as an enclosure in correspondence.
    The Literature Screen or Infocenter. You can make literature visible to users, so it is included in the list of literature that they see in the Literature or Infocenter screen.
