Analytical Reports for UPT and UPT with IRM Intersect Data
Siebel CRM consists of preconfigured reports that cover analysis of data collected by UPT. In addition, the reports also cover UPT-IRM intersection data and its analysis. Both sets of reports are described in the following table.
| Report | Description |
UPT - Build wise trending report |
This is a dashboard of preconfigured trending reports across various builds and executions of UPT. It helps analyze the increase in or change to test coverage in every build for any given artifact. The trending reports provide analysis on certain metrics captured by UPT and the reports can be enhanced to include other trending data as well. Each report can be drilled down further. You can also filter to compare two or more builds or filter on Build Number or Event Method. |
UPT Dashboard |
This is the main dashboard displaying analytic reports in a single view. You can filter the dashboard on one or more build numbers and drill down each report. Some of the salient reports are:
UPT Graphical Reports |
This dashboard contains graphical reports that can be filtered on build number. Some salient reports are:
UPT - IRM Intersection |
This dashboard is the intersection of IRM with UPT. It provides details on:
