Changing Inbox Downloading to Remote Databases
Inbox items can be set to download to regional and local databases. If your Inbox type is currently configured to download to remote databases, then you can change this setting.
Note: If your Inbox type is not currently set to download to remote
databases, then you can configure the inbox for use with remote databases.
For more information, see Configuring the Inbox for Use with Remote Databases.
This task is a step in Process of Administering the Inbox.
To change remote downloading for an Inbox type
- Navigate to the Administration - Inbox screen, then the All Inbox Types view.
- Select the Inbox type.
- In the More Info form, edit the Replication Level. - Values include: - All. Downloads the Inbox items to the regional and local databases.
- Regional. Downloads the Inbox items to the regional databases only.
- None. Does not download items to the remote databases. Note: If the Replication Level is currently set to None, then before you change the Replication Level, see Configuring the Inbox for Use with Remote Databases.
