Determining Whether Business Components Are Enabled for State Models
Complete the following procedure to determine whether a business component is enabled for state models.
To determine whether a business component is enabled for state models
- Navigate to the Administration - Application screen, then the State Models view.
- Create a new record, and click the select button in the Business Component field. - If the business component is listed in the Business Components dialog box, then the business component is enabled. You can create a state model for the business component. For more information, see Creating State Models and State Transitions.
- If the business component is not listed in the Business Components dialog box, then the business component is not enabled. You can enable the business component. For more information, see the other procedure in this topic.
- Delete or undo the new record.
