CUT Get Work Order Data Workflow
This workflow retrieves work order data from Siebel Communications to respond to a request from an external application. The external application calls this workflow using the available Siebel object interfaces. The external application retrieves the data from Siebel Communications directly, using this workflow as an API.
Workflow Description
This workflow performs the following actions:
  1. Get Work Order Data. This step uses the Query method of the EAI Siebel Adapter business service and the CUT Sample Work Order IO.
  2. Convert to XML. This step uses the Integration Object Hierarchy to XML Document method of the EAI XML Converter business service.
