Localizing Help
This topic describes how to deploy help in different languages. If you must use Siebel CRM in a language that is not available from Oracle, and you must deploy help in that language, then you must localize the help. For more information, see Siebel Global Deployment Guide.
To localize help
If the predefined localized help meets your requirements, then use that predefined help and exit this task.
Siebel CRM comes with predefined localized help. For more information, see Predefined Localized Help.
If the predefined localized help does not meet your requirements, then configure the ENU (American English) help to meet your requirements.
To translate the HTML source files, modify the flat files.
These HTML files constitute the help.
Test you modifications and correct any errors.
Distribute the localized help to the Siebel Servers and Siebel clients.
