Options to Drill Down to Another View
A drilldown is a type of field that allows the user to navigate from a field to another view that displays more information about the chosen record. Siebel CRM displays a drilldown primarily in a list applet. The drilldown object is a child object of an applet. A drilldown can be static or dynamic.
Consider the following drilldown behavior:
If the parent applet of a view includes a search specification, and if the user drills down on a field, then Siebel CRM applies this search specification to the destination view. For more information, see Options to Filter Data That Siebel CRM Displays in an Applet.
If the target view of a drilldown includes a visibility type that is different from the original view, and if the user drills down on a field, then Siebel CRM navigates the user to the first record of the destination view and not to the drilldown record.
Siebel CRM does not support drilldown on a multi-value group applet, pick applet, or association applet.
