Guidelines for Using a Table That Is Not an Intersection Table to Create an Intersection
You must reuse an intersection table only where it is a true intersection between two tables. The type of table must be Data (Intersection). Do not use a table that is not an intersection table as an intersection table only because it contains a foreign key to the table. This configuration can overload the table. For more information, see Reusing Predefined Objects.
Do not use a one-to-many XM table as an intersection table. Siebel CRM does not tune an XM table for this usage, and using it as an intersection table might cause poor performance. To support one side of the relationship, you must create a custom foreign key. This configuration might cause problems with Siebel Remote and Enterprise Integration Manager.
If no suitable intersection table exists between two tables and one is required, then you must configure the database. For more information, see How an Extension Table Stores Custom Data.
