Modifying Note Information for a Call
Complete the following procedure to modify the note information for a call.
To modify the note information for a call
Tap Side Menu and then tap Calls Items to display the following:
Call details and activities in the main pane.
Summary call details and a second level navigation list in the side pane.
Navigate to the call that you want using the navigation arrows in the main pane.
All activities for the call appear after the call details in the main pane.
Update an existing note for the call as follows:
Locate the activity that you want of type Note in the main pane.
Tap the record field that you want to update and update the field value.
You must navigate away from the record to save your changes to it.
Create a new note for the call as follows:
Tap Notes in the list in the side pane, and then tap New (the plus (+) icon) next to Notes in the main pane.
Enter the information for the new note in the fields that appear, and then save the record.
