Siebel System Fields
Every Siebel table contains the system fields described in the following table. Do not alter the contents of these fields.
| Column Name | Description |
CONFLICT_ID |
Unique value used to resolve Siebel remote routing conflicts if necessary; otherwise, value is zero. |
CREATED |
Date the record was entered. |
CREATED_BY |
User who entered the record (foreign key to S_USER). |
DCKING_NUM |
No longer used. |
DB_LAST_UPD |
Date and time the record was last changed in the database. |
DB_LAST_UPD_SRC |
Source of the instance or operation that changed the record in the database. |
LAST_UPD |
Date and time the record was last changed. |
LAST_UPD_BY |
User who last changed record (foreign key to S_USER). |
MODIFICATION_NUM |
Internally incremented number used for locking and to identify records for incremental updates of the Siebel Business Data Warehouse. |
ROW_ID |
Unique row identifier. |
