Starting and Ending a Break
Complete the following procedure to start and end a break.
To start and end a break
Tap Side Menu and then tap Shifts to display the following:
The Shift list in the main pane.
The Calendar showing the activity planning information in the side pane.
Tap a break record in the main pane.
Tap Start when you start the break to record your start time and start date.
Tap Complete when you end the break to record your end time.
