Using Specialized Business Component Methods for EBCs
The following are the specialized business component methods that are supported for use with EBCs.
IsNewRecordPending Business Component Method
This method can be called by using a script in the PreWriteRecord event to determine if the current record is newly created. If the record is a new record, then this method returns the value TRUE.
An example script for the use of this method follows:
var    isNewRecord = this.InvokeMethod("IsNewRecordPending");
GetOldFieldValue Business Component Method
This method can be called by using a script in the PreWriteRecord event to retrieve an old field value if needed. This method takes an input parameter, which must be a valid field name, and returns a string containing the old field value.
var    oldLoc = this.InvokeMethod("GetOldFieldValue", "Location");
SetRequeryOnWriteFlag (PreWriteRecord event) Business Component Method
In the PreWriteRecord event, this method can be used to put the business component into a mode where the current record refreshes from the data source after the write operation. EBCs typically use this method to refresh database sequencing column values on new record operations. This method takes an input parameter of TRUE or FALSE.
var    requery = this.InvokeMethod("SetRequeryOnWriteFlag", "TRUE");
SetRequeryOnWriteFlag (WriteRecord event) Business Component Method
In the WriteRecord event, this method informs the object manager that the write operation to the data source is processed by using a script rather than a database connector. At the end of the operation, the business component method, SetRequeryOnWriteFlag, can be called again with the FALSE parameter to reset the requery on write mode, if needed.
var    extWrite = this.InvokeMethod("SetRequeryOnWriteFlag", "TRUE");
// insert script here to commit the record via an mechanism channel
var    resetWrite = this.InvokeMethod("SetRequeryOnWriteFlag", "FALSE");
