Exposing MQMD Headers as Properties
In the inbound direction, that is, when a message is received from a queue, the EAI MQSeries Server Transport feature exposes the MQMD headers as properties of a property set. The supported headers are summarized in the last table, about MQMD Message Headers, in this topic.
Outbound MQMD Headers
In the outbound direction, that is, when a message is placed on a queue, the EAI MQ Server Transport supports the headers shown in the following table to be set by the caller.
Header
Value
CodedCharSetId
MQCCSI_Q_MGR, MQCCSI_INHERIT, MQCCSI_EMBEDDED, or any positive Long.
Encoding
MQENC_NATIVE or any positive Long.
Expiry
Any positive Long.
MsgType
Any nonnegative Long.
Persistence
MQPER_PERSISTENT, MQPER_NOT_PERSISTENT, or MQPER_PERSISTENCE_AS_Q_DEF.
Priority
MQPRI_PRIORITY_AS_Q_DEF or any nonnegative Long.
Report
The only settable value is MQRO_NONE.
ReplyToQ
Name of the reply queue, for example, myQueue.
ReplyToQ is set in the message header of an incoming MQ message by the sender application. This sets dynamically the queue for the response sent by Siebel CRM. ReplyToQ is valid for the ReceiveDispatchSend method.
Note: If the Response queue is specified using a static configuration, then the ReplyToQ header of the incoming message is ignored. The static configuration overrides dynamic queuing.
ReplyToQ can also be set by the Siebel application, as MQMD_S_In_ReplyToQ while using the Send method, to specify the response parameters.
ReplyToQMgr
Name of the reply queue manager, for example, myQueueManager.
ReplyToQMgr is set in the message header of an incoming MQ message by the sender application. This sets dynamically the queue manager for the response sent by Siebel CRM. ReplyToQMgr is valid for the ReceiveDispatchSend method.
Note: If the Response queue is specified using a static configuration, then the ReplyToQMgr header of the incoming message is ignored. The static configuration overrides dynamic queuing.
ReplyToQMgr can also be set by the Siebel application, as MQMD_S_In_ReplyToQMgr while using the Send method, to specify the response parameters.
You can set a MQMD message header for the Siebel application by specifying it as a property in a property set on the outbound side. Whereas on the inbound side, the MQMD message header of the response is exposed to the user as a property on the output property set.
On the inbound side, you can have the supported MQMD message headers as part of the output property set without having to do extra steps to see these MQMD message headers.
On the outbound side, you can set the MQMD message headers using the EAI MQSeries Server Transport. To modify the MQMD message headers on the outbound side, the property value for FullMQMDControl must be set to TRUE.
During the sending business service step (EAI MQSeries Server Transport.Send) within the workflow, input arguments are added that can modify MQMD headers. Once the property FullMQMDControl is set to TRUE, you can modify other MQMD headers as the examples show in the following table.
Note: In workflows and scripts, you set and get MQMD parameters using their full names, for example, MQMD_S_In_Encoding.
Input Arguments for Outbound MQMD Headers
The following table describes examples of input arguments for outbound MQMD headers.
Property
Type
Example Value
MQMD_S_In_CodedCharSetId
Literal
1208
MQMD_S_In_Encoding
Literal
MQENC_NATIVE
MQMD_S_In_Expiry
Literal
MQEI_UNLIMITED
MQMD_S_In_MsgType
Literal
TestMsgHeader
MQMD_S_In_Persistence
Literal
MQPER_PERSISTENT
MQMD_S_In_Priority
Literal
MQMD_S_In_ReplyToQ
Literal
MyQueue
Literal
MyQueueManager
Note: When using the Message Type header (MQMD_S_In_MsgType), make sure that the message type set makes sense in context. For example, if the Send method is used to send a message to MQSeries, then do not set the MsgType to MQMT_REQUEST. If the SendReceive method is used to send and request a response from MQSeries, then the MsgType of MQMT_REQUEST is applicable (this is automatically set by the Siebel application). In the previous table, MsgType is set to TestMsgHeader.
MQMD Message Headers Exposed as Properties in a Property Set
The following table summarizes the MQMD message headers that are exposed as properties in a property set.
Field
Data Type
Description
Input or Output Property?
AccountingToken
MQBYTE32
Accounting token
Output
ApplIdentityData
MQCHAR32
Application data relating to identity
Output
ApplOriginData
MQCHAR4
Application data relating to origin
Output
BackCount
MQLONG
Backout counter
Output
CodedCharSetId
MQLONG
Character set identifier of message
Input and Output
CorrelId
MQBYTE24
Correlation identifier
Output
Encoding
MQLONG
Numeric encoding of message data
Input and Output
Expiry
MQLONG
Message lifetime
Input and Output
Feedback
MQLONG
Feedback or reason code
Output
Format
MQCHAR8
Format name of message data
Input and Output
GroupId
MQBYTE24
Group Identifier
Output
MsgFlags
MQLONG
Flags that specify attributes of the message or control its processing
Output
MsgSeqNumber
MQLONG
Sequence number of logical message within group
Output
MsgType
MQLONG
Message Type
Input and Output
Offset
MQLONG
Offset of data in physical message from start of logical message
Output
OriginalLength
MQLONG
Length of original message
Output
Persistence
MQLONG
Message persistence
Input and Output
Priority
MQLONG
Message priority
Input and Output
PutApplName
MQCHAR28
Name of application that sent the message
Output
PutApplType
MQLONG
Type of application that sent the message
Output
PutDate
MQCHAR8
Date when message was sent
Output
PutTime
MQCHAR8
Time when message was sent
Output
ReplyToQ
MQCHAR48
Name of reply queue
Input and Output
ReplyToQMgr
MQCHAR48
Name of reply queue manager
Input
Report
MQLONG
Options for report messages
Output
UserIdentifier
MQLONG
User identifier
Output
Version
MQLONG
Structure version number
Output
