Mapping Between Property Sets and XML
An arbitrary property set hierarchy can be serialized to XML and an XML document can be converted to a property set hierarchy using the XML Converter business service. This service is used by the Business Service Simulator screen to save property set inputs and outputs to a file from eScript.
Each part of a property set object has a corresponding XML construct. The following table shows the mappings between parts of a property set hierarchy and their XML representation.
| Property Set Component | XML Representation |
| PropertySet | Element |
| PropertySet Type | Element name (if Type is not specified, then the element name is set to PropertySet) |
| PropertySet Value | Element Character Data |
| Property name | Attribute name |
| Property value | Attribute value |
| Child Property Set | Child element |
