Associating Entitlement Templates with Products
You associate entitlement templates with products in the Service Information view.
This task is a step in Process of Administering Entitlements.
To associate an entitlement template with a product
Navigate to the Administration - Product screen, then the Products view.
Select a product record, and click the Service Information view tab.
On the link bar, click Entitlements.
Create a new entitlement record, and complete the fields as appropriate.
Some fields are described in the following table.
Field Comments Name
Select an entitlement template.
Agree Line Item Products
Select this check box to indicate the product from the agreement line item is copied to an automatically generated entitlement that users create by clicking the Auto Entitlement button.
Entitlement Template Products
Select this check box to indicate all products associated with the entitlement template are copied to an automatically generated entitlement that users create by clicking the Auto Entitlement button.
All Contract Line Prod Flag
Select this check box to indicate the products from all agreement line items are copied to an automatically generated entitlement that users create by clicking the Auto Entitlement button.
