Changing System Preferences for the Cycle Counting Engine
You can change the system preferences for the Cycle Counting Engine.
This task is a step in Process of Administering Cycle Counting.
To change the system preferences for the Cycle Counting Engine
Navigate to Administration - Application screen, then the System Preferences view.
Select a system preference for the Cycle Counting Engine.
For more information about the system preferences for the Cycle Counting Engine, see the following table.
In the System Preference Value field, enter a new value.
To implement the changes to the system preferences, restart the Field Service server.
The following table describes some system preferences for the Cycle Counting Engine.
| System Preference Name | Default Value | Description |
BucketAvailCDtobeCounted |
OnHand, Customer-Owned |
Specifies the valid values for the availability code of the inventory level. The values come from the Bucket Availability Code LOV, and individual values are LIVs. |
BucketStatusCDtobeCounted |
Good |
Specifies the valid values for the status code of the inventory level. The values come from the Bucket Status Code LOV, and individual values are LIVs. |
Only the inventory levels (buckets) with an Availability field value and a Status field value that match the values in these system preferences are included in the cycle counting process.
