Configuration Parameters for the Cycle Counting Engine
The Cycle Counting Engine generates cycle counting headers and cycle counting products by using the configuration information from the Cycle Counts view of the Inventory screen. For more information, see Generating Cycle Counts (End User).
Cycle counting uses the following configuration parameters:
  • ABC or XYZ count basis. The method for cycle counting.
    • A, B, or C classification. The product classification that is based on the financial value of the product. A has a higher value than B, and B has a higher value than C.
    • X, Y, or Z classification. The product classification that is based on the turnover of the product. X has a higher turnover than Y, and Y has a higher turnover than Z.
    A product can have any combination of class A, B, or C and X, Y, or Z (for example, AY). However, cycle counting is based on either ABC or XYZ, not both.
  • Frequency. The interval in days between physical counts of inventory at a location. For example, if the counting frequency is 7 days, then you count inventory every 7 days.
  • Period. The time period in days allotted to counting all A or X, B or Y, or C or Z product classes at a location. For example, if the counting period for class A or X products is 90 days, then the Cycle Counting Engine includes all the products in this class in the part list at least once every 90 days.
  • Start Date and End Date. The time span in calendar days when the Cycle Counting Engine creates cycle count records.
For example, you configure an inventory location for counting on a financial value basis (count bases of ABC). There are 100 class A products in inventory. You count all of the these products in 20 days (period A/X of 20 days). Every 5 days (frequency of 5 days) you spend as much time as needed to count a quarter (5/20) of these products, with the goal of counting all of these products in 20 days. Counting periods do not have to be even multiples of the frequency.
The following table lists the applicable data and views for the configuration parameters that the Cycle Counting Engine uses.
Configuration Parameter Applies to View
Cycle count basis: ABC or XYZ
Inventory locations
Inventory Locations view of the Inventory screen
Inventory location types
Inventory Location Types view in the Inventory Administration view of the Administration - Service screen
Cycle count class: A, B, or C and X, Y, or Z
Products associated with a specific inventory type
Inventory Options list in the Fulfillment view in the Service Information view in the Products view of the Administration - Products screen
Products associated with specific inventory location
Product Inventory view of the Inventory screen.
Frequency
Inventory locations
Period for A/X, B/Y, and C/Z
Inventory locations
Start date and end date
Inventory locations
Cycle Count List view of the Cycle Counts screen
Note: If you can set a configuration parameter at different levels of inventory, then the parameter for the more specific level takes precedence over the other levels. For example, the count basis (ABC or XYZ) at an inventory location takes precedence over the count basis for an inventory type. The cycle count class (A, B, or C; X, Y, or Z) for an inventory type takes precedence over cycle count class for a product.
