Creating Rule Sets for Agreement Validation
Typically, the Agreement Validation validation rule set is provided in the preconfigured Siebel Field Service application. However, if no such rule set exists in your installation, then perform the steps in the following procedure.
This task is a step in Process of Setting Up Agreement Validation.
To create a validation rule set for an agreement
  1. Navigate to the Administration - Data Validation screen, then the Rule Sets view.
  2. Create a new rule set record, and complete the fields as appropriate.
    Some fields are described in the following table.
    Field Comments
    Name
    Type a name for the validation rule (for example, Agreement Validation).
    Business Component
    Select the appropriate business component (typically, Service Agreement).
    Business Object
    Select the appropriate business object (also typically, Service Agreement).
  3. Click Activate to release the rule set.
    Note: To revise the validation rule set, click Revise, and update the rule set. Click Activate again to release the rule set.
