Parameters for the Fulfillment and Part Locator Engines
By specifying input parameters for the Fulfillment and Part Locator Engines, an administrator can define the processing for a specific set of orders (using order search specifications), for a single order (using the order ID), and for a single order line item (using the line item ID). The following table describes the parameters for the Fulfillment and Part Locator Engines.
| Parameter | Value | Description |
InputMode |
ORDERSEARCHSPEC |
Specifies the WHERE clause to set up criteria and fulfill the orders that meet that criteria. |
ORDERID |
Specifies the single order ID to fulfill. The engine fulfills the specified order. |
LINEITEMID |
Specifies the single order line item ID to fulfill. The engine fulfills the specified order line item. |
TEMPTABLE |
Places all required parameters into a temporary table with a temporary Client Request ID and passes that ID to the server to retrieve the parameters from Temp Table. Note: Do not
run component jobs in TEMPTABLE mode to call the Fulfillment and Part
Locator Engines. This mode is reserved for interactive engine jobs
sent directly from a client application. |
ClientReqId |
A row ID for retrieving line items input from the temporary table |
This parameter is required when the InputMode parameter is TEMPTABLE. |
RowId |
A row ID of a single order to fulfill or a single order line item to fulfill |
This parameter is required when the InputMode parameter is ORDERID or LINEITEMID. |
OrderSearchSpec |
Where Clause |
This parameter is required when the InputMode parameter is ORDERSEARCHSPEC. |
