Process Flow for Invoicing Service Requests or Activities
The following figure shows the process flow for invoicing service requests or activities as follows:
  • Service Request (CreateCharge) consists of Orders and Activity:
    • Orders: Create Charge, CreateOrder Charge.
    • Activity: CreateCharge, Create Service Charges.
  • Activity consists of Time, Parts, and Expense:
    • Time: CreateCharge, CreateTimeCharge, CreateTimeEntitlementCharge.
    • Parts: CreateCharge, CreatePartsCharge, CreatePartsEntitlementCharge.
    • Expense: CreateCharge, CreateExpenseCharge, CreateExpenseEntitlementCharge.
Process Flow for Invoicing Service Requests or Activities. This image is described in the surrounding text.
If you want to create your own process flow, then review the process flow in the previous figure. This figure shows the flow of control for the methods that are available in this business service. This figure also shows that the user properties on the business component control the CreateCharge method. These user properties pass information to the user interface about the business services and methods to call.
The following table lists the user properties that you must edit to change the process flow for the service charges. You can add or remove each individual item in the process flow using these user properties.
Business Component User Property Value
Service Request
ChargeExecuteBusinessComponent1
Action
Service Request
ChargeExecuteBusinessComponent2
Order Entry - Orders
Action
Time Sheet Daily Hours
Action
FS Expense Item
Action
ChargeExecuteBusinessComponent3
FS Activity Part Movement
Action
ChargeBusinessService
Invoice Charges Business Service
Action
ChargeBusinessServiceMethod1
CreateServiceCharges
CreateOrderCharges
FS Activity Parts Movement
CreatePartsCharge
ChargeBusinessServiceMethod2
FS Expense Item
FS Expense Item
CreateExpenseCharge
FS Expense Item
CreateExpenseEntitlement Charge
CreateTimeCharge
