Recording Movements of Defective Products in Repair Records
In a repair record, you can record the movement of defective products that relate to the repair. To record product movements, you update the Location field in the repair record and the inventory level (the Availability field and the Status field) in the repair record. These updates automatically generate inventory transactions.
To record the movement of a defective product in a repair record
Navigate to the Repairs screen.
Drill down on the Repair number (#) field for a selected repair, and click the More Info view tab.
Complete the fields as appropriate.
Some fields are described in the following table.
Field Comments Location
Select the location of the product.
Availability
Select the availability of the product. Values include In Transit, On Hand, and On Order.
Status
Select the condition of the product. Values include Defective and Good.
