Siebel Audit Trail for Remote Users
The following information applies to remote users:
Disconnected users cannot view audit trail records. However, after they synchronize with the server, audit trail records are created on the server for their transactions.
Information that is used to create audit trail records is synchronized, but the records are not synchronized.
If the transaction is rejected during the conflict resolution, then the corresponding audit trail record is also rejected.
Note: It is recommended that you do not change the Audit Trail business service.
