Abbreviation Fields | ABBR 1
Use this user property to get the abbreviated field values according to the field value selected in the Display drop-down list in the Function Space Diary.
Abbreviation Fields | ABBR 1 | Description |
Value |
Setup Style Abbr;Expected Num Abbr |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets |
Usage |
The usage is the same as the Abbreviation Fields | ABBR 0 user property. |
