Actual and Abbreviation Field 4
Use this user property to define the actual field and corresponding abbreviation in the Function Space Diary.
Actual and Abbreviation Field 4 | Description |
Value |
Expected Num;Expected Num Abbr |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary and TNT SHM Function Space Diary Total Availability Applet Applets |
Usage |
The usage is the same as the Actual and Abbreviation Field 1 user property. |
