Aspect BC ReadOnly: History
Use this user property to set the business component to read-only mode, if the value of the field specified in the user property is Y.
Property Description/Value
Value
Calc Locked Flag
Parent Object Type
TNT History Opportunity business component
Usage
When Aspect is defined and the current aspect is Aspect, then the current record becomes read-only when the value of the specified field is Y.
