Associating Volume Discounts with a Property
The following procedure details how to associate a predefined volume discount with a property.
This task is a step in Setting Up Volume Discounts.
To associate a volume discount with a property
  1. Navigate to the Property Pricing Admin screen, then the Properties view.
  2. In the Properties list, select the required property and click the link in the Property Name field.
  3. Click the Volume Discount Matrix view tab.
  4. In the Volume Discount Matrix list, create a new record, complete the fields, and save the record.
    The following table describes some of the fields.
    Field Comments
    Name
    Enter a name for the discount at this property.
    Description
    Enter a description of the discount.
    Volume Discount
    Select the discount to be associated with this property.
    Start Date
    The date from which the volume discount will become effective.
    Start Day
    This field is automatically populated after the Start Date field is completed.
    End Date
    The date after which the volume discount is no longer effective.
    End Day
    This field is automatically populated after the End Date field is completed.
    Product
    Select a product to which the volume discount applies.
    Product Line
    Select a product line to which the volume discount applies. Select either a product or product line.
    Note: You can only specify either Product or Product Line for any Volume Discount.
    Created By
    The User Id of the user who created the Volume discount.
    Created Date
    The date on which the volume discount was created.
