Associating a Default Catalog Category with a Property
As a requirement for creating property-specific products, you must associate a catalog category with the property. This category becomes the default catalog category for products associated with the property. When you create a property-specific product, Siebel Hospitality automatically assigns that product to the default catalog category of the property.
This task is a step in Roadmap for Setting Up Menus and Packages.
To associate a default catalog category with a property
Create a new property record or select an existing property record.
For more information about setting up a property, see Adding Property Records.
Select a category in the Default Product Category field.
The selected category becomes the product category for all products created for this property.
