Associating a Product Feature with a Function Space or Category
To associate a product feature with a function space or a category, follow this procedure.
This task is a step in Process of Managing Function Spaces, Sleeping Rooms, and Categories as Products.
To associate a product feature with a function space or category
  1. Navigate to the Administration - Product screen, then the Products view.
  2. In the Products list, query for a specific space or category.
  3. Drill down on the Name field.
  4. In the Product Key Features list, create a new record.
  5. In the Feature field, select a product feature.
    Note: When defining the key features for a function space, you must select features with a Product Line value of Function Space, to make sure the space matches the function agenda feature requirements.
