Booking Drop Conflict Popup Default
If the pop-up applet name is not specified in the Booking Drop Conflict Popup Name user property, then this user property is used to specify the default selection option in the booking conflict pop-up window.
Booking Drop Conflict Popup Default | Description |
Value |
Option |
Parent Object Type |
TNT SHM Compact Function Space Diary, TNT SHM Function Space Diary, TNT SHM Function Space Diary Total Availability Applet |
Usage |
When a booking conflict occurs, a user can select either the OK, Option, Overbook, or Cancel option in the booking conflict pop-up window. If the pop-up applet name is not specified in the Booking Drop Conflict Popup Name user property, then this user property is used to specify the default option. |
