CanInvokeMethod: NavigateToView
Use this user property to enable or disable the NavigateToView method.
Property | Description/Value |
Value |
[Id] IS NOT NULL |
Parent Object Type |
TNT SHM Function Line Items List Applet applet |
Usage |
Enables or disables the NavigateToView method. The value shows that when no records are displayed in the parent applet, the NavigateToView method is disabled. |
