Color Code Major Axis 3
Use this user property to specify the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary.
Color Code Major Axis 3 Description
Value
8
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets
Usage
Defines the time scale for which the color coding and icons are displayed in the major axis of the Function Space Diary. The value 8 represents the LIC value for the Day/Half-Hour time scale.
