Default Aspect
Use this user property to define the Default Aspect property for an applet.
Property Description/Value
Value
History
Parent Object Type
TNT History Opportunity List Applet applet
Usage
When the aspect is defined, the business component user properties function that is based on the aspect is defined. The Default Aspect is defined as History.
