Defining Active and Backup Colors
Colors for both active and backup bookings can be defined. The colors defined here are used to differentiate between the two types of bookings in the Function Space Diary. For example, if blue is defined as the color for backup bookings, these bookings will appear with a blue border in the Function Space Diary.
This task is a step in Defining Function Space and Asset Inventory Status Indicators.
To define active and backup colors
  1. Navigate to the Function Space Administration screen, then the Function Space Diary Administration view.
  2. In the Active & Backup Information section, select colors in the Active Function Space field and Backup Function Space field.
    For example, select the values Blue and Yellow.
