Defining Setup Style Translations for Function Spaces
The Setup Style Translation view allows the administrator to specify the required area for each attendee for previously defined setup styles. This translation table is used during the process of generating quotes to start function space availability checks.
This task is a step in Process of Defining Day Parts, Status Indicators, and Setup Style Translations.
To define setup style translations for a function space
Navigate to the Function Space Administration screen, then the Set Up Style Translation view.
In the Set Up Style Translation list, click New.
In the new record, select a predefined setup style, and define the Approximate Square Feet or Square Meters required for each attendee.
These fields are mutually exclusive; filling one automatically converts and populates the other field.
If applicable, add comments, and then save the record.
