Disable Hierarchy: TNT SHM Order Entry
This user property is used in C++ code to disable or enable the function hierarchy in the active business object when the Day number (#) field and Date field for the function change.
Disable Hierarchy: TNT SHM Order Entry Description
Value
Y
Parent Object Type
TNT SHM Function business component
Usage
