Displaying Quote and Order Functions
You add menus and packages to functions as function line items. A function can be associated with a quote or order. You can access functions associated with specific quotes from the Quotes screen. You can access functions associated with specific orders from the Orders screen. For more information about functions associated with quotes, see Managing Functions Associated with Quotes. For more information about functions associated with orders, see Creating Function Orders.
Note: You can also add a menu, package, menu item, or event order item to an event check as a line item and associate it with a function. For more information, see Adding Menu and Package Line Items to Event Checks.
This task is a step in Process of Associating Menus and Packages with Functions.
To display quote functions
  1. Navigate to the Quotes screen, then the List view.
  2. Identify a quote that includes the function to which to add a menu or package.
  3. Drill down on the Name field.
  4. Click the Functions view tab.
To display order functions
  1. Navigate to the Orders screen, then the Event Order view.
  2. Identify an order that includes the function to which to add a menu or package.
