Double Click Applet Method
Use this user property to specify the method to call on a double-click event.
Property Description/Value
Value
AddProducts
Parent Object Type
TNT Menu Product Pick Applet applet, TNT Package Product Pick Applet apĀ­plet
Usage
When a user double-clicks one of the parent objects, the selected record is added to its originating or parent applet. The value of this user property is AddProducts, which is a custom method. If you do not use the double-click event, this user property can be deactivated.
