Enable Color Icon
Use this user property to enable or disable color coding in the Function Space Diary.
Enable Color Icon Description
Value
Y
Parent Object Type
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets
Usage
Turns color coding on or off in the Function Space Diary. If the value is N, no color icons are displayed.
